- Redmi Note 9 Pro [joyeuse]
Filléres Redmi érkezett
A call centerekbe viszi az AI-t a Microsoft
it Új AI-eszközöket visz az ügyfélszolgálatot ellátó call centereknek a Microsoft.
Holo Launcher
v1.2.5
- Better grid control
- New action: Toggle dock
- New option: Dock as overlay
- New option: Auto-Close dock after app-launch
- Bug fixes
- TranslationsThanos was right.
Swype Beta v1.3.1.9274
Nekem ez van fent. Ez a legfrissebb? Tényleg sokkal jobb lett, nem telepít külön valami Dragon appot, gyorsabb, szép témák vannak hozzá stb.
Egyetlen bugot vettem észre, hogy a hangdiktáló gomb vagy mi ritkán de eltűnik, a nyelvváltás visszahozza.
Thanos was right.
Megjelent a jetAudio Plus v1.9.0
A verzió jellemzői:
* WMA support (depends on your device spec)
* Show/hide button bar by album art touch
* Pitch shifter (for Plus only)
* New widgets (4x2, 4x3, 4x4) (for Plus only)
* Shake to play next/prev track
* Show/Hide album art on Folders tab
* Share function
* Full screen option (hide status bar)
* Sort in Songs tab
* Always display option for status bar icon
* Fixed M4A lyric display problem
* Hebrew/Spanish language added
* Other minor enhancements and bug fixesThanos was right.
Frissült az ADW Ex, méghozzá elég komolyan.
Thanos was right.
hi
What's in this version:
Revamped engine to merge ADW/ADWEx functionalities.
Settings to modify icon sizes
Settings to modify text colors, shadows, etc
New visual configuration helper
New ADWSetup screen for an easier way to add items and access tweaking functionality
Improved android compatibility from 1.6 to 4.1!
New visual AppWidget picker (android 4.1+ only)
New theme engine with improved support for most popular launcher themes
New ADWSettings layout
New animations when moving desktop items
Fling desktop items to send them to the trash
New optional ActionBar for most common actions
New desktop transitions
New desktop indicators
New way to hide apps from your app drawer
New app drawer tabs to manage unlimited application groups
New app drawer visual styles
New app drawer open/close animations
New gestures settings to perform common actions
New easy way to manage folders
New different folder visual styles
New folder previews styles
Manually reorder folder contents by drag-and-drop
Double tap desktop icons to bring up editing menu
Long press desktop Widgets to bring up editing menu
New easy way to adjust screen sizes/margins
New backup/restore systemThanos was right.
Leváltotta nálam a Holo-t. Egyrészt teljesen támogatja a Go Launcher témákat(sztem az Apex/Nova témákat is de azt most nem tom kipróbálni) másrészt az új mappanézet jó lett, ezt hiányoltam régen belőle hogy lássam milyen ikonokat tettem egy mappába. Amit még mindig hiányolok belőle az az ikonválasztó, hogy úgy lehessen ikonokat tenni az asztalra mint Go Launcher-ben.
Ezen kívül még egy valag extra van benne, rengeteg új beállítást kapott, főleg ICS/JB ficsöröket amik persze működnek GB-n is. Első indításnál lépésről-lépésre végig vezet a főbb beállításokon.
Kb. 15MB-ot "eszik" jelenleg.
Thanos was right.
válasz freemanone #4534 üzenetére
Én a lopásvédelem miatt használtam, meg egy kicsit kíváncsi voltam, sztem a legtöbben csak a biztonsági érzetük miatt használják.
(#4538) atillaahun:
Ma már 2 frissítést kapott az ADW EX, egy FC-t nem fognak benne hagyni, érdemes most kipróbálni, GB alatt nekem reggel se volt probléma.
Thanos was right.
Próbáld ki a Note Everything-et, van fizetős és ingyenes verziója is.
A Camera360-nál lehet megoldaná ha bemennél az alkalmazások kezelése részhez és nyomnál rá egy Adatok törlése opciót, ez nem távolítja el csak frissen telepített módba állítja, a fotóidt viszont mentsd le biztos ami biztos.
Thanos was right.
Jó ezen nem fogunk összeveszni. Nekem fura, elindulok valahova, elindítom a zenét és hozzá se nyúlok amíg ki nem kell kapcsolnom.
Mondjuk a PowerAMP-ot még így se tudnám 2. helyre tenni, max. 3. lehetne mert a Winamp jobban tetszik, de valamelyik nap nézegettem a PowerAMP-ot, elindítottam egy mappában egy számot és nem játszotta le az utána következőket. Lehet én voltam a béna pedig az EQ-n kívül nem állítottam semmit.
Thanos was right.
Thanos was right.
ADWLauncher EX v1.3.3.8
-New desktop transitions
-App Groups manager to add/remove/rename/reorder Application Groups
-Overall style (Light/Dark)
-Visual list of transition effects/Drawer styles
-Custom list for random desktop transitions
-4 icon backgrounds folder previews
-Portrait sensor/landscape sensor orientation
-New ADWSettings layout for 7" devices (Android 3.x+)
-Security settings
-The ADW Config dialog can be assigned to gestures
-LauncherActions next/previous screen
-Fixed direct dial icons *Samsung* devicesThanos was right.
Total Commander 2.0
v2.0 final
-Drag&Drop files to other panel and to sub-folders
-Built-in media player with equalizer, play queue, background playing, full screen video in landscape mode, stream from LAN and -WebDAV plugins (they need to be updated too)
-Improved stability of background operations
-Select a range of files/folders with a long tap on an icon
-Copy to external SD-Card on Android 3.0 or later even without root rights
-Multi-Window support for Samsung Galaxy N7000, N7100 and N8000
-Set permissions and owner/group for selected files
-Custom scroll thumb also in the editor to scroll long files more quickly
-Custom date and time formatThanos was right.
Aki PC-n szerette a Beat Hazard játékot annak itt az androidos verzió: Link
Én most találtam meg és instant buy lett, gondolom tableten még jobb játszani de nekem telefonon is borzasztóan tetszett. Internetes rádiók is vannak benne, le a kalappal a fejlesztő előtt.
Itt pedig a relaxáló változat: Link
A 2 app összesen nincs 1000Ft de az élmény ennél sokkal többet ér. Viszont arra az app is figyelmeztet, HOGY EPILEPSZIÁS rohamot okozhat azoknál akiknek ilyen betegségük van szóval csak óvatosan. Ja és eléggé akkumulátor gyilkos de ez érthető is.
Jó szórakozást!
Thanos was right.
A legfrissebb Google Play verziója 3.10.9?
Thanos was right.
Valamelyik ADW Launcher Ex szakértő meg tud abban erősíteni, hogy az app drawerben nem lehet olyan csoportokat létrehozni mint a Holo Launcherben vagy Go Launcherben, hogy pl. Legutóbb használt vagy Kedvencek?
Nem én akarom beletenni az appokat hanem használat alapján adja hozzá értelemszerűen a legutóbb használthoz a legutóbb használtat a kedvencekhez meg azt amit sokszor indítottam el?
Szerintem ilyet nem lehet ADW Launcher Ex-ben de jó lenne ha valaki megerősítene.
Thanos was right.
● Tilos a warez!
- XGS24 - Jövőre érkezik az új Fable
- Formula-1
- Milyen légkondit a lakásba?
- World of Tanks - MMO
- nVidia tulajok OFF topikja
- Hasbro Marvel Animated Series Venom bontatlan díszdobozos
- 4TB-os IronWolf Pro ( ST4000NE001 , 7200rpm , 256MB, CMR ) merevlemezek!!! Bontatlanok, garral!!!
- Lenovo ThinkPad P50, I7-6820HQ, 16GB RAM, 756GB SSD, FHD, 2 év garancia, Áfás számla!
- Hama Star 05 106-3D fotó-videó állvány táskával Új
- Új állapotú Nintendo Wii konzol
